pontiac
Anyone out there have some ideas about improving HP on a 76/350 f/bird w/2 brl,dual ex, auto???? Biggest bang for the least bucks of course. Down the road I should come across a deal on a 400 or something! I just want to get by w/what I have if poss. Thanks
Originally Posted by bsbober
That sounds good! Approx what hp. would be gained?? Just a guess! Would more be gained by taking heads off and have them redone while doing the rest of this???And be worth the added cost??
If I get to a certain point of the upgrade and couple hundred more would make a big diff ,then I'm up for it !! For right now I'm not able to talk thousands $$$ I'm only looking for a few more Hp.
Thanks for the input ! The cam and carb sounds doable but the headers are a diff story. All the headers I've looked at so far indicates that one of the bolts have to be drilled and tapped for installation. I have the orig.manifolds w/dual flow-mstr now so would headers make a big improvement over this set-up?? If I need to drill/tap a bolt on the heads for headers, should I have something done w/heads?
