565ci bbc tunnel ram carbs pump gas best choice?
thanks alot any exsperience or helpful advise.
-i want to run a twin carb set up on a tunnel ram with regular pump gas on a 565ci bbc engine with 5 speed trans manual and solid roller cam aggresive radical cam.this is for street driving and quarter mile race maybe once a month.
- i was thinking twin 750 range carbs?
Big difference between 87/93 octane and E-85........You will be able to run more compression and a little more radical cam with E-85..you will also need the carbs blueprinted for e-85 and the Fuel pump E-85 Compatiable.
E-85 is around 105 Octane. 8)
what area do you live in ?
only tunnel ram id use on a motor that big is a fabbed one(big dollars)if i was u id look at dart or super vic with a SINGLE 1150 or 1050 minimum cfm....
if u want a motor that goes build with performance parts,if u want a bling bling motor,then go with the old school two fours
