throttle body spacer
This will now answer your question directly, but you can make spacers out of a piece of wood using a gasket as a template. I used piece's of a red wood post (4X4) cut various thicknesses to try several different heights of spacers for my 4.0L HO jeep some years ago. I made 3 different heights and changed them out back to back to test where the torque band moved to or if I could tell any change. After determining which height worked best, I bought one made of phenalic or plastic material. This eliminated the trial and error buying several $80.00 spacers to find the answer. The wood works well and is easy to cut out with a jig saw and drill the holes on a press to make sure they are true perpendicular. Red wood is not necessary, but something without course grain is best so it does not split on you. Plywood or partical board may be needed for your larger size spacer footprint, you can get up to 1.125" and can stack your wood pieces too if you need higher pieces than that. Making 3 out of 1/2" and progressively stacking them might be easier than three different thicknesses for your application? The cost of the correct spacer design and thickness is worth $80.00 if you knew which one was best on the first try in my opinion.
Bruce
Bruce
Originally Posted by txhunter69
ok thanks that wood dont leak though
Bruce
