head bolts vs cylinder studs
Studs are usually always better and a must with alum. heads, because of the growth of alum. A good set of chromemolly head bolts will be fine with steel heads, but the head stud kit isnt that much more. If your buying new Id get the studs.
Bolts if you run a factory block that have the head bolt holes going into the water jacket, they seal better. Also if you have a door car and want to be able pull the heads, studs can be a pain. For blind hole blocks like World and Dart studs are fine.
If you look at ARP VS ARP the bolts are awsome and not going to have any issues. The studs are for when the engine gets torn down regurally, the stud has better memory then a bolt. So it comes down to how much you want to spend and how often the engine is appart.
Horse a piece, but if i were building it i would use studs, even though the blk will have blind holes and if you're useing a tricky rocker setup it's much easier to re-torque the heads with studs. IE, jessel shaft with 1.530 springs. $50.00 difference is not a lot on a good motor.
PS, Todd you have 5 bolts around the cylinders,VS 4 with a s/blk
I would say studs are a good choice .. espeacially if you are using an aftermarket block that the studs do not go into the water jacket.
I have sbc with studs .. but i have to say i did have an issue with the studs seeping coolant. It was an assembly issue...and the motor was new. I had to remove all the studs one at a time and reseal them..since then i have had no issues.
I would suggest Loctite 567 for sealing stud treads.. its a very stout thread sealer.. although its expensive it WORKS.
Take Care
Keith
Take Care
Keith
