help!!!!!!!
Well I've never heard of all poly mounts causing anything like that, although I've never tried it either. I run front and mid-motor plates with a poly trans mount and have never had a problem with that. I don't know what would have caused it but, I would think that case is garbage now
It broke behind the front pump, even the sealing surface for the pumps O-ring is gone! An Ultra bell bolts to the front of the front pump.
WOW, I sure am glad I saw this post! I have never used poly mounts either, was going to put them on my latest "affair" (as my wife calls them). Thinking I may pass on that idea now!!
Good luck figuring it out.
Rudy
Finally figured out how to resize pictures!!
Rudy
your having the same problem we are having on the 3rd 1 now we have a stroker motor with a balancer and flywheel for internal balance they are saying that might be doing it we are putting a 400 balancer and flywheel and try it again will let u know what happens if u figure yours out would like to know what it is hope u or i can get this figured out it costing alot
If you did it in the burnout, then I would think it has to be in the Driveshaft...Maybe a U-Joint Failed maybe the driveshaft was bent?
There wasn't alot of load on it during a burnout. So I am guessing you had the 7/8-1" of play for the driveshaft also. I had a U-Joint Break the Rear one twice..about the finishline and it did the same thing. I would put my money on a U-Joint Failure. I don't think the mounts had anything to do with it. I run stock rubber shells on the frame and a replacement rubber trans mount. No issue's.
