Best way to warm up an alcohol motor????
I have a 632 BBC Brodix bb3Xtra Ported heads , 15.5 C/R, Tunnel ram with bugcather and direct port methanol injection. Whats the best way to warm up my motor before going racing. Do i lean it out on idle to warm it up or just run it at med RPM after i have gained oil pressure.Every body here tells me differant things.I would like to start a discussion to see if i can settle it.
I also have a gas primer set up on my fogger system. works good, because your squirting fuel down each cylinder.
Originally Posted by us7race
Seems like I see alot of guys add a lean out valve to help warm them up.
A controlled vacuum leak...
Curtis
