Cam Help for 502 Chevy
I am building a 502 gen VI for mud racing. I am using a '80 fullsize blazer. I plan on using dominator flange Team G with a 1050 dominator. It has JE pistons, forged crank and rods and plan on Brodix RaceRite rectangle port heads milled to 110cc. I expect around 10.5-11.0 to 1 compression. I am looking for some solid roller cam specs to reach 700-800hp. Hopefully, I am not out of line with my expectations. Any help would be much appreciated. Thanks
I would use a victor or super victor intake and go in and clean up the rough casting and gasket match it.You need to research between these two intakes to see which one would be best for the 502.
here is a pump gas 502 made into a 509, that I built for a local guy. It was a gm perf. 502/502 core engine, and thats exactly what it turned out to be. So, we threw away every part, except the block, crank, and head cores, which are 2.25 intake valve edelbrock Perf. Rpm oval port heads that say GM performance parts. Not bad, $7500, 1 year, and throw everything away. But anyhow, with a fairly radical port job on those heads, and a 270-278 at .050 solid roller on pump gas, with a Victor 4500, and a 1050 carb, it made 735hp and 650 ft/lbs.
If you ran more compression, and the heads you have have more potential, it could make a lot of power. Where are you located, I am in St.paul,Mn, I noticed you said you run in Mn. If want any further details, let me know
Frank
Advanced Performance
www.get-ap.com
Frank
www.get-ap.com
I am located in Bismarck ND. My head choice might have changed to a little bigger head, Dart Pro 1 or Brodix BB2 plus. What is your preference? What are all the specs on that cam and also RPM range?
Thanks
Thanks
Frank
www.get-ap.com
Frank
www.get-ap.com
