powerglide stuff
hey guys got a delima i ordered the imput shaft for a 1.76 and they sent me the box for a 1.76 my shaft is 12 5/8 as the 1.76 is but they sent me a 12 7/8 long can i use it? also where does the "wedding band go? man im really in a pickle here any help? thanks mike
The 1.76 input shaft is supposed to be 12 7/8" and the 1.82 input shaft is 12 5/8". So, it sounds like they sent you the correct one for the 1.76. If you truly need the 12 5/8" long shaft, you can not use the 12 7/8" as the torque convertor would not be able to slide on far enough. The gold wedding band fits inside the small slinger/shield that rests against the hub inside the high gear drum.
Bill M
Bill M
what kind of input shaft did you Buy Mike stock or aftermarket..such as a vasco etc...????
i will tell ya somehting Bill m is on the stick..this fella knows his parts..i am inpressed BILL...ROCK ON !!!!! 8) 8) ..
hes correct on where the band goes..........
later Brian
later Brian
Thanks, Brian. It also helps that this past weekend I was freshening up a glide. The JW Powerglide Transmission book is a pretty good handbook that I use.
When I started racing over 20 years ago, I had the money for the parts or the labor. I bought lots of books and learned how to work on it, so that I could have money for more parts. So, I learned a lot of the ways to not do things. One of the most fun was finding out that there are over 100 needle bearings in the countershaft of a Muncie 4-speed held in by wheel bearing grease.
Bill M
Bill M
as usuall you guys are here for us racers thanks again bill brian we bought a tci shaft[which im going to send back and get the right one ] from jegs also carp from a-1 transmissions here in artesia gave us a great deal on some clutches and steels so ill be ok there everything else looks great just my mistake will cost us a weekend of racing! maybe it will rain this weekend! well bill thanks again and thanks for checking in brian you guys rock!!! mike in new mexico
