RESPONSE FROM TESTA1 TO 1923T
#21
Testa, :roll: Who in their right friggin mind would return anything to you for a full refund at this point and time? You've already proven to be a SCAMMER so who would want to risk losing anymore than they already have. If you're trying to indicate that perhaps the parts went missing after the Michigan recipient receieved the parts-dream on. As for Dennis being in Canada and you not having his home address, I believe you got your money and it cleared the Bank, its alot quicker and cheaper to have parts sent to a friend in Michigan then it is to have them brokered into Canada. As you probably know Canada is geographically larger then the U.S., but Dennis is a mere 15 minutes away from the Michigan recipient and not all that far from you. Do the right thing and send the missing parts.
#22
Sounds like you know the the guy in Canada,?
#23
Administrator
Originally Posted by "keepinup"[/quote
hello,
David Testa thanks for for input here :P
#25
Administrator
Originally Posted by Scorpion1110
TopSportsman1, it sounds like you may be checking static IP addresses
Correct assumption?
Correct assumption?
#28
Between this deal with Testa and Bigtoys454/weissberg this forum is getting next to impossible to figure out the good from the bad.
Tom, can you use that magic delete button and clean some of this garbage up so the forum is a little more reader friendly??? Thanks.
ops:
