8" converter with powerglide spline...??
you have to machine the stator support on the front pump to install a bushing when you are using a turbo shaft. You can buy aftermarket PG shafts that will handle alot of hp. But for serious power a turbo spline shaft is stronger.
Most if not all competent converter companies are putting the bushing in the converter so there is no need to install one in the stator support. I've never used BTE so it does warrant a phone call..
That sounds like what he said...something about the pump...iduno...Everything in my trans is from COAN ,including the converter...and this all took place back in 2002 when he built the trans the first time for me...if that tells you anything.I do know he is a damn good tranny guy. He races a tube chassis beretta with an aluminum 415(or 421 don't remember) sbc 18 deg headed motor. Runs a terminator set up on it.
