cooling in the pits
I think Hammers talking about spraying the trans pan not the radiator. I've sprayed mine in the later rounds seems like you just get back, hook up your charger and the track is calling your class back to staging lanes. I also have sprayed water on the converter.
I will be switching to Mobile 1 syn fluid this year to help some also, make sure you guys wanting to run hyd fluid get the non foaming type.
lots of feedback ! good ! I was looking at plumbing some sort of external pump into the pan, then to a cooler , this will cool the oil in the pan, and if you start the car a couple of times, this should cool the convertor as well, just haven`t found a pump that will work....I run a 5000 stall in a glide behind a pump gas 588 alum. it gets hot after 3rd round esspecially on those hot days, the guage tells the story, and I like to keep it at 150 for the start of each round, I have heard some tranny manufactures have their own oil that they claim runs cooler, but I haven`t researched it yet. thanx for the ideas.........a pump would really get my interest though...and alot less screwing around with water and a leaf blower........which are still good ways to cool,,but with less time in the pits, during later rounds, a pump will free up some time, for other things. I do run a large B&M cooler with fan, but not enough when you start getting on the trans brake.
take your pan and plumb some small steel lines through it like a cool can.... run nitrous on a solenoid to the pan, wire it on the transbrake switch! When your on the brake it will cool ur tranny down when its building the most heat!
Now thats what I`d call a cool idea...good one !!! I could hook it up as a purge line, then when I release the trans brake, it could feed the engine..LOL, a couple of extra lines and switches and we`re ready to go..
