Optima Batteries
Originally Posted by russ67chevelle
ONE NOTE TO PASS TO FELLOW RACERS-BEST THING FOR YOUR REAR MOUNTED BATTERY SET UPS IS TO HAVE A GOOD HEAVY DUTY LINE FROM ALTERNATOR BACK TO THE POSITIVE ON BATT. I USED HEAVY 4 GAGE WELDING WIRE AND ABSOULUTELY NO PROBLEMS WITH 1 OPTIMA RED BATTERY AND POWERHOUSE 120 AMP ALT.IT WASNT HOLDING AS GOOD OF A CHARGE WITH SMALLER GAGE WIRE!!!!
One thing I don't like about this is that even with the master switch in the off position you still have 12 volts to that Alternator all the time :shock:
Originally Posted by fla1976
You can get away from the constant source to the alternator by installing a relay that is activated by the master cutoff switch. That way there is no power with the switch off.
You have a part# for a relay that will take a #4 wire????
lots of good batteries out there now,,I do like the optima red and you need to get a real alternator if your going to run on the street, I`ve been screwing with batteries and alternators on my street car for years, and the best I`ve come up with is the red optima (because its lite)and a good 100 amp alternater, you have to find a way to run an alternator, sooner or later you will have a problem, and you wont be likeing it. just my oppinion ...I run a single red, and lots of fans and pumps, and it starts my bbc like nothing!
Originally Posted by rlmotorsports
The best battery by far that iv ever owned is the Kinetik just one bad battery.
I now sell them i still sell optima also but these are catching on now .
