good troublershooters needed
I installed the springs and the car did the same thing. I called MSD tech and was told it could be electro magnetic interferance. I disconnected the alternator wire and belt did the car did the same thing. I put foil on the magnetic pick up wire, didn't work either. I am going to try to rev it up to about 4000 and cut the fuel pump when the weather permits, to see if that is causing interferance. I have a spare BBC with a bad crank if all else fails I will build my spare motor and drop it in the car, at least I will know if it is a mechanical problem. because I have had 3 carbs on the motor already. If anybody Knows of a race shop with a excellent reputation in southern calif. send me a PM. By the way the car did this before I changed the cam.
thanks for all your help
steve
steve
As posted before, Whatever you are using for an "ON switch" change it. Painless rocker switch, toggle switch, anything its a 5 or 10 dollar fix!!!! I chased a bad Painless switch for 4 weeks. Racecar idled fine and you could roll into throttle till a certain rpm before it started missing. If you matted the thing it was breaking up terribly from the get go. Would not have believed it till I had it happen to myself.
The car has been sitting through the winter. But I tried messing with it a little. The converter is a nitrous holeshot that flashes out about 2900 rpm with this motor. The cam is a hydralic roller I have set the preload from 1/2 to 1 turn. My next plan is to borrow a friends distrubeter and wire up a second battery that is just dedicated to running it. That should take all electrical gremlins out of the equation. I have changed the electrical switch. The exaust is 3 inch flowmaster that dumps right before the rear axle. The blancer has not slipped on the elasometer. I have changed the areomotive return fuel system, to a dead head system. I do apprecate all the input from everone, and can't wait to flog my car above 5000rpm. :twisted: :shock: :lol: :twisted:
