what are the best metering blocks for a 1200 dominator?
Thread Tools
Old 11-09-2016, 04:23 AM
curtisreed
curtisreed's Avatar
Hey Doug,
How did things work out with the wide body blocks? Did they get the fuel in you needed?
curtisreed is offline
Old 11-22-2016, 07:46 PM
brannonn
Have you checked the timing? I had the same problem with mine and I advanced the timing and fixed the problem.
Retarded timing will let the charge burn out the exhaust port/
brannonn is offline
Old 11-22-2016, 07:55 PM
brannonn
Have you checked your timing?Mine did the same and my timing was retarded letting the fuel burn out the exhaust header.
Advanced my timing and the exhaust temp and water temp came down to normal!
brannonn is offline
Old 11-23-2016, 09:51 AM
bowler
Curtis I went to 1 race with the wide blocks and put 98 jets and had the same problem, never got to dyno it, both people with the dyno's have a problem with zoomies, will try going up on jets
Glen just read your reply, I have 36 degrees in it next year will try bumping it up to 40 and see if it makes a difference.
Thanks Curtis and Glen will update next year!!
bowler is offline
Old 11-26-2016, 09:55 AM
brannonn
Moved mine to 40 with 116 fuel and dropped in to the 5's
brannonn is offline
Old 12-09-2016, 04:05 PM
jmarksdragster
jmarksdragster's Avatar
Did they open the angle channels on those metering blocks? They come with around a .136" exit, but need to be at least .160
jmarksdragster is offline
Old 07-14-2021, 02:16 AM
aquilesopkarg
Originally Posted by bowler View Post
I have a Pro Systems 1200, the motor is a BBC 565", 14 to 1, Patriot 360 heads that HRD did the chambers, the pro systems carb was really lean so I kept going up on the jets and the hi speed air bleeds Showbox jiofi.local.html tplinklogin went down to .026 smallest ones we had,still could not get the EGT below high 1300, then I had a friend took stock holley metering blocks and he drills the passage out they work but same problem, now I can't find the metering blocks that came with this carb SO i'am hoping you guys will be able to recommend what metering blocks to buy? Thanks Doug
What did you end up doing on this?
aquilesopkarg is offline
Old 09-13-2024, 07:43 AM
chrisgreen45
Curtis After placed my order for the BLP broad body parts, I saw that the bolts were not long enough. I contacted the business to inquire regarding why the blocks weren't included, and they verified that they were the supplier. I'm having them shipped in three days, and they should arrive tomorrow. I'll see how they perform because I have a two-day event this weekend. I'm going to start with smaller jets (.112) and work my way up. Doug spelling bee answers
chrisgreen45 is offline
Old 09-20-2024, 11:39 PM
chrisgreen45
Originally Posted by BigBlockMark View Post
Bowler, have some people interested in the 58 Delray. One couple drove here from about 100 miles away and we had a good time driving it around town. They seem pretty serious. I have the BLP wide body blocks on a 1250 for my new 582. Going to dyno soon. Had it running on my test stand. So far so good spelling bee answers
Thank you for sharing this nice post, which includes plenty of valuable information. I thoroughly enjoyed reading it.
Old 03-20-2026, 02:08 AM
lorlorenyeeben
Nachdem ich meine Bestellung für die BLP Broad Body Teile aufgegeben hatte, bemerkte ich, dass die Schrauben zu kurz waren. Ich kontaktierte den Anbieter https://leon-casino-app-game.com/ und fragte nach den fehlenden Blöcken; sie bestätigten, dass sie der Lieferant sind. Die Teile wurden innerhalb von drei Tagen versendet und sollten morgen ankommen. Ich werde testen, wie sie funktionieren, da ich dieses Wochenende ein zweitägiges Event habe. Ich starte mit kleineren Düsen (.112) und arbeite mich nach oben.
lorlorenyeeben is offline
