Need Good Head
#1
Junior Member
SHOW GUEST
Thread Starter
I thought I may get your attention...lol
I am looking for suggestions for aluminum heads for my BBC and wonder what other people are using. I know if I call companies it would be like asking the waitress how the soup is so I am asking here first.
I have a 502 Mark VI BBC rectangular port open chambered heads with 9.25-1compression. I am running a Comp cam roller with a 652 lift on intake and exhaust. Duration is 262. Victor manifold and a 1050 Holly tops it off. I am also using roller rockers, solid roller lifters and comp. guide plates and pushrods. This sits in a early 70's steel body Camaro. As I said I am looking for suggestions as what to look for in a set of aluminum heads. I know that bigger is not always better and the right combination will work best. I am looking forward to your suggestions
#3
Member
JUNIOR BUILDER
I'm considering AFR 325 with CNC bowl blend & chambers option for my 509. Here's an article how they performed on a very similar engine like yours:
http://www.airflowresearch.com/artic...le131/A-P1.htm
If you need more power, more the compression and bigger cam will get you an easy 100+ hp.
#4
Member
JUNIOR BUILDER
X2 on the compression, With the change to alloy heads & the cam your running I would think that you would be easily be able to raise it to at least 10.3-1 or more & still be ok with premium pumpgas.
#6
Administrator
RACING JUNKIE
Originally Posted by gimmemud
Curtis @ RFD is unbeatable
Give him a call,just tell him the gang at Racing Junk sent ya :P
http://www.raceflowdevelopment.com
703-339-1039
__________________
There Is 1 Thing Better Than Cubic Inches,,,More Of Them
#7
Senior Member
MASTER BUILDER
703-339-1039
#9
Senior Member
SENIOR BUILDER
there was a joke going around after I threw a pro stock team out of the shop
comparing me to the soup nazi, ..
http://www.youtube.com/watch?v=ihd4G...eature=related
In the area you are working, I'd stick to a Dart pro 1 with a good valve job, . small port, .. 310cc with CnC chamber option. No porting
just a mild bowl blend and good valve job.
Or you could do the Edelbrock Victor Jr based off the same casting
design I do my high end race heads from but with the valves relocated
to fit a smaller bore. 300cc intake port, fully cnc chamber 110cc, .
stainless valves, nextek roller spings for around $2600.
Point being I think you need to stick around 300-320 cc, .. use a good quality head casting, . make sure the chamber and piston combo
give you the proper compression ( 10:1 or more ) and have a good
valve job done.
You really won't go wrong if you keep the intake port small
and stick to name brand heads, .. don't get tempted by the cheap
import junk heads, ..
Also look at your exhaust, .. some heads in the range have the
exhaust port raised .300", .. and could cause a clearance problem.
Check if you have room, raising the exhaust port is good.
let me know if you need any more soup.
Curtis
