torgue converter broke
Old 06-17-2009, 03:03 PM
fullspeed383
Default torgue converter broke
well i was doing my burn out and the converter let go. i pull the trans out and drop the pan didn't have any big pieces of metal but real fine metal shavings, do i need to get rid of the cooler or how do i clean the cooler and lines. thanks for your help.
fullspeed383 is offline
Old 06-17-2009, 07:25 PM
jed5161
CRAFTSMAN
brake parts cleaner and compressed air. flush it both ways until comes out clean. If has ALOT of metal or feels restricted at all when blowing through it, change it out. Best to have trans gone through and everything cleaned out. It doesn't take much to stick a valve and burn trans up. I broke a set of pump gears and had a small piece stick a valve and burnt up reverse clutches because slipping backing up when trans brake applied
jed5161 is offline
Old 06-17-2009, 11:27 PM
chevyfireball
A professional radiator or trans place should be able to pressure clean it. It's a lot better than doing it yourself with an air hose.
chevyfireball is offline
Old 06-18-2009, 01:51 AM
TS1955
Go to NAPA and get a can (or 2) of Kooler Kleen part # 765-2614. works great!!!
TS1955
TS1955 is offline
Old 06-18-2009, 01:23 PM
fullspeed383
hey thanks guys oh yea it was a redneck converter only my 7 passes on converter on my 8th it let go i email redneck and told them what happen and all they could tell me was to send it back, and paid 150+parts and freight and they will fix it. i don't thing so i'll get a good one this time and someone that will stand behind there converter. thanks again.
Old 06-18-2009, 06:27 PM
dparker
All I can say is you get what you pay for.............
dparker is offline
Old 06-19-2009, 06:31 AM
kwkracing
All I can say is you get what you pay for.............X2!!!!!
Unless its a stock 305 dont put one of those convertors back in.
kwkracing is offline
