Ford 9" rear end
Old 08-06-2010, 06:02 AM
hammertime
Originally Posted by ccperf721p
It's probably a race prepped housing with a fill cap welded on the top and sealed axle bearings. 2 quarts would be plenty.
yes dont fill that one to the fill lol
hammertime is offline
Old 08-06-2010, 06:41 AM
THERATTLER
THERATTLER's Avatar
still should have the level plug on the side of the carrier shouldn't it ??
THERATTLER is offline
Old 08-06-2010, 08:55 AM
suicidebomb
Mine has both.
suicidebomb is offline
Old 08-06-2010, 10:13 PM
cepx111
Most rearends take around 3 quarts to fill completely to the "level plug" located on teh side of the housing, usually it's a inverted 3/8 square drive.
In race trim though, most guys will cut that amount by about a quart, hence the 2 quarts recommend.
I run 2 qts in my dana 60 and its alot bigger than a 9 housing :wink:
cepx111 is offline
Old 08-07-2010, 10:01 AM
shaybliss71
Default Right on...
Originally Posted by fla1976
The fill plug should be on the side of the housing a little higher than the level of the pinion gear. It sounds like you are looking at the pressure vent on the top of the housing.
fla 1976 you ar right on. On the front side of my housing ( trans side )almost about 2/3rds up is a plug. My rearend is a race built / pro rearend. Its also between the "fins" on my MW chunk. Thanks again.
shaybliss71 is offline
Old 08-07-2010, 10:05 AM
shaybliss71
Thanks for all the help everyone!!! Im good to go. Will be using Richmonds synthetic 75 - 140 .
Old 08-11-2010, 06:33 AM
headsup1320
Default Re: Ford 9" rear end
Originally Posted by Shaybliss71
I just bought a new car and it has a braced ford 9". I would like to know how much rear end dope goes in? Three quarts or ? Thanks
pull one axle fill housing until when you look in the axle tube with a flashlight the lube has reached the bottom of the tube then make a note of the amount used
headsup1320 is offline
