Weak springs?
Old 10-26-2008, 08:55 PM
OneBadGMC
Originally Posted by cepx111
This is copied from the original post, very confusing.
1967-UP CHEVROLET V-8 396 THRU 454 CU.IN.
MODERATE COMP. ONLY, GOOD UPPER R.P.M.
TORQUE & H.P., HIGH COMP. RATIO REQUIRED
Moderate comp only, then high comp required? wt?
I'd go with the springs recommended from crane they know whats best for their cams, or go with a comparriabled set with them same seat pressure, same installed height and coil bind.
Goodluck, Charles
You sure about that?
Their website and cam card directly contradict each other.
OneBadGMC is offline
Old 11-01-2008, 10:22 AM
triniemi
Here's Crane's webpage about the 99876 springs:
http://www.cranecams.com/?show=brows...&lvl=3&prt=123
I have my springs at 1.905 to 1.965 installed height. Maybe I should shim all of them closer to 1.900 to get few lbs more of seat pressure?
triniemi is offline
Old 11-01-2008, 08:25 PM
OneBadGMC
Why not shim them for 180-200 LBS, and see where you wind up with installed height? Then check to make sure you dont have binding at full lift.
Old 11-11-2008, 11:33 PM
poncholvr
i would go heavier than (needed) to get the job done to be safe
i wouldnt want to float a valve kiss a piston,and shuck the valve keepers - resulting dropping a valve,and ruining a motor
for the few bucks buy what you need
valve designs are so a weak spot in a motor
poncholvr is offline
