400 Build
Quick question with the stock block filled to the bottom of the water pump holes how much horsepower can it hold this will be a strip only motor. also can you fit a 3.875 or a 4.00 crank in the stock block with some clearancing?
We have a 406 filled that makes 702hp. You need to sonic test the block and look for thin spots in the cylinder walls and prepare yourself for things to move around. I think a better option would be one of the new SHP blocks. They may seem pricey but by the time you have all of the machine work for splayed caps and such you will be very close to what you can buy one for. JMO.
3.875 OR 4.00, small base circle cams, SJ rods, 3/8" rod bolts, stroker clearanced rods, lots of time grinding and fitting. It can be done but it is not easy. My 2 cents.
Curtis
Curtis
its a two bolt the block is bored .30 over sonic tested line honed ready to go im going to stud it so i would be happy around the 650 hp mark. it has all forged internals only thing left to get is cam and heads if anyone has any suggestions on that to get to 650 im all ears. thanks for the reply.
I think i'd stick with the 406" setup, it's a lot easier. You'll need a .900 BS or smaller cam, somewhere between .630 and .650 lift on 106 lobe C/L solid roller. The Dart steel heads make good power and are cheap by comparision, 1 7/8" headers. I have 2 also 1 is a 4 bolt the other is a 2 bolt. I fill them to the bottom of the water pump, studded both. I go one step further. I tap the steam holes and put 1/16" pipe plugs in them, this helps keep the bolt holes from cracking to the steam holes. 650 is fairly easy to reach with a 406" motor with a good tune up.
I didn't/don't put splayed caps on them, i do use studs on everything i build or run. There is a main gurdle that sells for about $70.00 for the 400 blk. it kinda keeps the webs from moving around. I also run 350 main bearings cranks with bearing spacers and drill a 1/8" hole in the upper bearing to get more oil to the mains. I drill that at 45 degrees from the top oiling hole. All the bearing spacers that i have seen have the top half grooved.
Curtis
Curtis
A helicopter or is that one of them modified storm chaser deals.
Cp
