az
Thread Tools
Old 05-28-2009, 03:09 PM
cubed
Default az
xxx
cubed is offline
Old 05-28-2009, 03:58 PM
TS1955
That is correct. You align them up when putting the engine together, it makes it easier. But like you said, when it's on compression stroke on #1 cyl. both dots, crank & cam will be on top.
TS1955
TS1955 is offline
Old 05-28-2009, 04:41 PM
cubed
Default c
cccc
cubed is offline
Old 05-28-2009, 10:31 PM
cepx111
Default Re: cam sprocket
Originally Posted by Sidracing
hi guys, when my chevy small block is on tdc on comp. stroke is the dot on the cam sprocket at the top? thanks.
NO, that is NOT correct.
The cam sprocket DOT should be at the bottom or 6 o'clock position and the crank sprocket DOT will be at the 12 O'clock position.
It;s reccomended to degree it in per the cam card, but dot to dot will get you pretty close.
cepx111 is offline
Old 05-29-2009, 01:25 AM
TS1955
Cepx, when you initially put in a cam you will align the marks up, BUT when you rotate the engine to "compression" stroke on #1 cylinder both dots will be at 12 o'clock.
TS1955
TS1955 is offline
Old 05-29-2009, 02:20 AM
johnracer
TS1955
Yep, that's correct......
johnracer is offline
Old 05-29-2009, 02:42 AM
topsportsman1
Administrator
The cam sprocket DOT should be at the bottom or 6 o'clock position and the crank sprocket DOT will be at the 12 O'clock position.It;s reccomended to degree it in per the cam card, but dot to dot will get you pretty close.
Charles that position would be #6 TDC firing
topsportsman1 is offline
Old 05-29-2009, 06:49 AM
oldandtired
oldandtired's Avatar
There are two TDC for each rotation of the camshaft. This may be what is confusing.
One TDC is compression, the other TDC is the overlap between exhaust closing and intake opening.
Always easier to install chain when the dots are close together.
oldandtired is offline
Old 05-29-2009, 07:30 AM
desoto30
I've wondered for ages why it's been done that way,one would think that the dots would be close when #1 is @ tdc compression.This position (6 tdc comp) also puts the fuel pump lobe on the heel IIRC.
desoto30 is offline
Old 05-29-2009, 08:44 AM
cubed
cv
cubed is offline
