nitrous
Originally Posted by talgregory
thinking about useing nitrous with my alcohol injection can any one tell me what should i do the type kit i have is a hitman by NX nitrous :?:
8) thank for the help 8)
I run a terminator with a NX Stage 6 Alky kit, enrich with alky and have no issues they seem to have the best setup.
I also run a terminator what do i have change to make the nitrous work ? Also how much will it pick up on a 100 shot . do you have to change the timeing :?: :?:
Picking up depends on what your setup is now and how long you want to spray for.
i have aholly blue . what kind of fuel do you use racing or alcohol with the nitrous. :?:
Here is the list/links of things I purchased when doing this
http://www.nitrousexpress.com/Pages/...orconv6Alc.htm
Nitrous kit
http://www.nitrousexpress.com/Pages/genX.htm
Gen x2 kit, purge & bottle heater
http://www.jegs.com/i/Holley/510/12-815-1/10002/-1
Holley Black
http://www.apdracing.com/fuelsystems.cfm
Bypass regulator
Best deal I found was jegs racer discount on the nitrous kit.
Nitrous kit
Holley Black
Bypass regulator
On my Altered I have a red holley electric fuel pump for a primer pump to prime the engine with alcohol before I cold start it. I've had this setup for many years with no trouble but I use top lube in my alcohol so maybe that helps with the corrosion.
