1.428 60' time with 9.65 et is my 60' time slow?
#42
i ran at madras sat. & sun., put the msd 6a in now my tach reads correct and the shift light works! set it at 6900 rpms, sat. temps in mid 80's with clouds air was 4500', ran 1.484@60 and [email protected]: 1.505@60' and [email protected]; 150.4@60' and [email protected], first round 1.513@60' lifted; round 2 1.485@60' lifted; round 3 1.452@60' ran 6.465 @97 mph ! break out. sunday backed compression off 2 marks (rear shocks) weather was clear and cool ran1.462@60' [email protected]; and 1.486@60' and [email protected]; and 1.460@60' and [email protected]; round 1 red light 1.492@60' and [email protected]. ran both lanes with a small difference between them, i tried 7# air then went to 8# after first run (sat.) then went back to 7# for the rest of the race, it was a race both days so its hard to play with the air and shock settings. next race 2 weeks and i'am going to put a delay box in it and try s/pro. bowler
#44
Originally Posted by bowler
i ran my new car at woodburn 9-8-09 it ran 1.428 60' 3.993 @ 330 6.171 @ 1/8 at 112.95 mph, 8.056 @ 1000' 9.652 @ 1/4 mile with a speed of 139.42 and i lifted about 100' early my question is my 60' slow, my car is 2400# 109" w/b, strange struts (single adj.), rear susp. is 4 link with double adj. strange coilovers, 4 link intersect is about 50" out and 2" above ground, i have struts adjusted in the middle and the rear shocks are set in the middle on both compression & rebound. also the weight is close to 50-50 and my rear tires are hoosier 32.5x16.5x15 (co7) thanks for your help Bowler
johnracer has a roadster with a shorter wheel base than yours and seems happy with his wally winning roadster after raising his ride height to raise the crank higher and raised his IC to get his to react better.
Bruce
#45
Bruce
Johnny
#47
Wow Doug, aren't you something. Best engineered car award! That is great Doug. Johnny has a great eye doesn't he!
Good call John.
John, Doug is tightening the back spread to help his reaction like you did on yours. Doug is not scarred to change his 4 link and knows his car very well. I am confident he will have it right where the wants it to be soon, if he has not already. You both are a pleasure to talk to about chassis set ups because you both actually do them and don't just take opinion poles on changes.
Bruce
Good call John.
Bruce
#48
Johnny thats me! thanks again Bruce raced, at madras this saturday cloudy and cold in the 40's they hot lapped us to try and beat the rain, (sunday rained out) i used a delay box for the second time ever first run let go of the button and nothing happens? i let off the gas oh crap nailed it had a .567 spun and ran [email protected] run 2 a .488 red ran [email protected] run 3 .560 ran [email protected] run 4 first round a nice .673! ran [email protected] round 2 .570 ran [email protected] fianlly ran someone that could cut a light and my day was over my 60' were (thru out the first one) 1.468, 1.421, 1.454, 1.457. with 6 1/2# air, just proves you can't teach old dogs new tricks! even with a delay box i can't cut a light i had a friend run it for t/o and he had a .518 light! i'am done for this year, but i will stay with the delay box also i'am going to sell the donovon block, oil pan & crank so i can build a 434" or a friend has a bbc fresh this year that dyno'ed at 825hp ran 920's @ 3400#. next year will be fun Bowler
#49
Definately stick with the box. They're not magic and take time to get used to it. Personally, I think the bigblock would be the ticket. I've always run run smallblocks until I got my 522 and I probably won't go back. What a difference!! It just keeps on pullin!!
Congrats again,
Johnny
Congrats again,
Johnny
#50
just fired up my new motor last night, first time out will be Boise Idaho's oldies race June 5-6 this motor is a Dart block with a compustar 4" crank 6" h beam rods & JE pistons 58 cc AFR heads suspose to be 14.7 to 1 on gas, maybe i'll see those 1.30's @ 60'. bowler
