hp numbers?
Old 08-19-2009, 03:18 PM
brett46
Default hp numbers?
What I have is a 383 w/brodix track 1 heads 221cc runners,67cc chambers 2.08 in ,1.600 ex, flat top pistons,10:1,cam;242 and 249 @ .050,.571 and .579 lift w/1.6 aluminum rockers, intake; holley pro series tunnel ram w/dual 650s 1 7/8 fenderwell headers It will be in a 2800 lb 46 GMC tubbed ladderbar gasser , running 4.62 gears with a th 400 3500 stall w/ trans brake. What do U think? any ideas ? hasent been built yet.
brett46 is offline
Old 08-19-2009, 03:25 PM
OneBadGMC
375 hp
OneBadGMC is offline
Old 08-19-2009, 03:57 PM
bjuice
Administrator
bjuice's Avatar
i gotta a 406ci with dart iron eagle cast heads 2.02's....flat tappet cam..5.20 lift range.....vic jr intake...750 Holley HP
its also 10:1 motor with flat Tops
It made right at 460hp on the dyno with almost same amount of TQ.
i know the 383's are a little different set up..but i would say you should be in the 420/430 range .....
i think it would be quicker if you took that Tunnel ram off and went with a good intake and Good single carb.
bjuice is offline
Old 08-19-2009, 04:14 PM
brett46
Yea I was waiting for the GET RID OF THOSE CARBS , but if I get tired of them it is real easy to swap out. Or just shoot a little giggle gas at it!
brett46 is offline
Old 08-19-2009, 04:29 PM
MEMRACING62
64cc chamber vs 67cc ??
MEMRACING62 is offline
Old 08-19-2009, 05:17 PM
ashbros
My boy had this exact same motor in his S10 about 8 - 10 years ago except he had a strip dominator intake on it. Truck was 100% stock. He ran a 10.73 at the track with a 2500 stall converter, a 350 turbo tranny, 3.73 gears w/ alburn posi, no suspension and a single jimmy evans 850 or 950 (Can't Remember) blower carb on it. Fuel - Pump Gas.
Installed a 125 Shot put him in the 10.20's - 10.30's
Thru a 144 baby blower on it with the 125 shot and it dipped into the 9's.
The major amount of work he performed went into the heads, mild port job, but polished the runners until you could see yourself intakes and exhaust...
Check out the very beginning of the video on my race space. there is a picture of the truck before they started installing the chassis work on it.
ashbros is offline
Old 08-19-2009, 05:35 PM
brett46
planning on cleaning up the heads. The heads are advertised as 64cc chambers on one ad and 67cc on another will have to cc them to get real numbers. mid tens is kinda my goal. so that is encouraging
brett46 is offline
Old 08-19-2009, 10:08 PM
cepx111
Ditto on losing the twin carb(s) and tunnel ram, they look cool, but are way overkill on most apps.
If your wanting mid 10's, I'd slap on a good single plane intake and a 750 Dp and you should be close.
The bog your gonna get off line with them twins is going to kill your sixty foot which in turn will kill and your ET> JMO.
Cp
cepx111 is offline
Old 08-20-2009, 07:32 PM
brett46
I have a generic single plane manifold and 650 carb also, but the tunnel ram is going to stay for now just going to race it when I can. When I get bored I will changed it. I am going up on compression though around 11.5 to 1
brett46 is offline
Old 08-20-2009, 09:31 PM
Tod74
11 and a half to 1 on the compression is really pushing it for pump gas, so if you are going to run good gas might as well go with more compression. I have ran 11 to 1 in a 406 on premium pump gas but wouldn't go much over that. JMO
Tod74 is offline
