-   -   how much fuel pressue at idle on 570 big block chevy, 871 bds blower, two doms 102 (https://www.racingjunk.com/forums/showthread.php?t=34440)
roadhogsnomads 05-23-2014 05:37 AM
on all corners, 16 percent over driven, 120 fuel, 10 feed 10 return
jmarksdragster 05-23-2014 11:54 AM
Electric pump 6 psi should do it.
roadhogsnomads 05-23-2014 01:02 PM
thanks that's what its set at.
hshufelt 11-06-2014 06:56 AM
6 to 10 lbs should be fine
ggmaxwell 10-05-2016 02:07 PM
fuel pressure
[QUOTE6 at idle but what that is important is under a load at 7000rpm at 145 mph you need at least 4 lbs to 5
