Witch spark plugs for alky carb??
I normally run a AR3933 on gas. I am new to the alky stuff and was just currious what everyone else is running with a carb and alky..... It is a APD 1150 going on a 540 in a dragster if that helps any.
witch
NGK R-5671A-9 alcohol. -8 for gas
Re: Witch spark plugs for alky carb??
Thanks, I would have been lost with the 3933.
I run both autolite and NGK, but like David says you really have to index the Autolites, because of the longer tip.
JMO Zip. |
(Post 253655)
| All times are GMT -8. The time now is 12:51 AM. |
