-   -   horsepower/tourqe and 1/4 mile est (https://www.racingjunk.com/forums/showthread.php?t=30734)
hotrod1994 07-25-2011 06:29 PM
355 sbc 4 bolt main high nickel block
12:1 compression
afr eliminator aluminum heads 210cc intake runner 2.08 1.6 valves
65cc combustion chamber
comp extreme energy 284
adv 284/296
@.050 240/246
.507/.510 lift
110 lsa
weiland team g intake
Holley 1050 dominator
malory uni light distributor and hy fire 6 digital cd ignition
it will be in a 76 camaro around 3500 lbs
th350 3500 stall
28x10.5x15 m/t et drag slick on weld drag lights
4.56 gears -? what kind of rpm's do you guys think she turn across the line?
thanks guys
-logan
oldandtired 07-26-2011 04:33 AM
Cam does not fit the rest of the combo - JMO.
JEFF69Z28 07-26-2011 07:02 AM
CARB IS WAY TO BIG THAT THING ONLY NEEDS A 750 TO 850 CFM CARB.
