-   -   Banging out big block (https://www.racingjunk.com/forums/showthread.php?t=30292)
kwines 04-24-2011 05:45 PM
I have a 482 big block that I ran 2 nights last season with my sons holley 1050 carb on it. It ran great. I ordered a new carb that was set up for my engine and it would launch great but would bang out shortly after it launched. We tried bigger jets and several trys with no success. The next week we put his carb back on and it started banging out again. Nothing else changed from last season. We checked plugs, valve settings, timing and a different coil. Nothing was found to be bad. Any ideas?
wazup 04-24-2011 06:45 PM
Did you check fuel. Pressure, volume, ect.
kwines 04-25-2011 03:50 AM
Yes, we pulled fuel line and ran pump into a fuel jug untill fuel cell was empty. It ran a full stream the whole time.
hammertime 04-25-2011 04:49 AM
Ohm he plug wires, and maybe check the cap and rotor. Seen a rotor crack this weekend, causing a issue like your having.
taps 04-25-2011 10:26 AM
carb
have you tried a tube from front vent to rear with notch cut at top
kwines 04-27-2011 04:27 AM
We have not tried the vent tube-but will. Also, I'll take cap off and inspect for cracks. Thanks guys
wazup 04-27-2011 04:47 PM
There is something that i have seen before is rpm and retard chips that go bad.
kwines 04-27-2011 05:02 PM
I'll try different chips if dist cap looks good. Thanks
kwines 05-04-2011 04:27 AM
I found out I have at least 2 broke valve springs. Some check to be a little weak. Thanks for all the help.
