what is the difference in blowers set up for gas or alky?
Gas=No Strips,Lots of Clearence.
Alcohol=Strips usually Blacks and Whites,Tight Clearence. Gas Makes ALOT of Heat,so with if you had a Tight Blower on Gas? You would Get ALOT of HOT Air! Later G 8) |
An alky blower will be hard anodized for protection against corrosion.
TS1955 |
| All times are GMT -8. The time now is 10:51 AM. |
