-   -   Dynamic compression (https://www.racingjunk.com/forums/showthread.php?t=28999)
superstreeter 10-11-2010 07:18 PM
Dynamic compression
How many engine builders really look at dynamic compression, when building an engine to run on pump gas, I want to use all the compression I can without getting knock,Ive used the calculators online, and Camshaft #s can really make a difference here with ABDC #s, how important is dynamic when building around a cam ? compression can change quite a bit from one cam to another..I`ve heard If I stay in the 7.75 to 8.0 to 1 range, this is best, so if I go with 10-1 static, cam selection gets tuff, or do I find a Cam and build the compression to match it ???
superstreeter 10-12-2010 05:26 PM
Wow... no takers ? lol. I guess no one uses "Dynamic" ?
kwkracing 10-12-2010 08:24 PM
The guys that know all the ins and outs of adjusting the compression as per the cam openings and overlaps are not going to freely give advise. I wish i knew more on this subject as well.
cepx111 10-12-2010 09:18 PM
You might try Yellowbullet
oldandtired 10-13-2010 05:04 AM
Very difficult to measure, as even advancing / retarding the cam timing makes big changes in dynamic compression.
What we are talking about is the "capture" of the compression and the efficiency that the pistions movement has on drawing in the charge and expelling the spent gasses. Every aspect has a part in the process, timing, rod length, octane, plug heat range, intake plentum size, runner size, header size and length, etc.
markdunlap 10-13-2010 01:52 PM
Dynamic
Since you mentioned cam phasing, you may be able to select the optimum intake lobe centerline, in an asembled engine, by finding the highest cranking compression of different positions.
superstreeter 10-13-2010 03:49 PM
couldnt that be done on a calculator ? or not ? lol
jmarksdragster 10-13-2010 08:13 PM
http://www.yellowbullet.com/forum/sh...d.php?t=287013
Ignore the ranting of a lunatic over there.
cepx111 10-13-2010 09:14 PM
LMFAO :lol: :lol: ol~ Ed is a trip
TheRabbit 10-14-2010 04:13 AM
Well I'm not even gonna try to give an answer and show just how stupid I am. All I could do is call my motor builder (SVRE) and ask him. I'm sure he'd rattle off what you need to know or how to figure it, but I'd just get it all messed up by the time I tried to repeat it.
