400 Sbc
Just wondering what would cause no end play on the crank.
Thrust surface on the crankshaft worn. Also possible but not likely the rear main block faces worn and letting the rear main slide back and forth.
JMO Zip. |
Is this a new build?
Zip,
Wouldn't that cause too much end play? |
Rear cap not alined to block,needs moved forward or backward.Bill.
Yea its a new build with a new crank on a gm 817 block with clevite H series bearings.
Did you "set" the rear main bearing before you torqued the rear cap down? You should bump the crank foward then backward before torquing. Dave
Originally Posted by doorracer
Zip,
Wouldn't that cause too much end play? Oldandtired, is right if the cap is not doweled you have too smack the crank forward and backward before torquing the cap down. also they sell an over size rear main to solve the crank wear, it's possible you accidently got one of these in the main bearing set. If you have a set of calibers pull the rear main cap off and measure the the bearing width the check the crank thrust surfaces width. JMO Zip. |
| All times are GMT -8. The time now is 11:06 AM. |
