-   -   Another Mopar engine question (https://www.racingjunk.com/forums/showthread.php?t=27208)
barry0383 02-01-2010 05:34 AM
On this 440 unfired engine I purchased, I have a question on the top end oiling. It is a 76 block and I wonder if it oils thru the rocker shaft or the pushrods. The reason I ask is that the lifters have a hole in the top as if they pump thru the pushrods. And the rockers have a squirt hole as if the pushrods lube them. The problem is , the pushrods are solid and could not lube anything. I noticed the Comp catalogue lists two different numbers for the lifters and I have another 440 that doesn't have holes in the lifters either on the side or top. I just don't want to crank this thing with mismatched parts and not be oiling the top end. Any clarification would be appreciated.
promod45 02-01-2010 04:35 PM
rockers
the mopar oils thrue the block and then the head then to the rocker shaft, so the pushrods should be solid
mopar1968 02-01-2010 05:58 PM
Promod is correct :!: :!:
''JUST MY TWO CENT'S WORTH''
barry0383 02-02-2010 08:41 AM
Thanks guys, appreciate the help.
