-   -   427 BBC crank making contact with piston (https://www.racingjunk.com/forums/showthread.php?t=27059)
altune 01-19-2010 05:30 PM
I am doing rebuild on a friends engine and after removing the oil pan I noticed the #6 piston on the bottom , looks like it was making contact with the crank. It is only on one piston and I thought it was very odd.
The contact is minimal but worrying.
I checked the rod bearing thinking maybe if it was worn out the extra play would make it hit the crank , but it was still in good condition. I also took a good look at the rod pin bearing and it looked fine also.
Anybody ever experiance anything like this before ???
Any help appreciated.
Thanks
Al
BEAST477 01-19-2010 05:52 PM
Is it possible this engine has been rebuilt before and the marks could be from a bearing issue earlier? Did they make mention of any noises to you before you tore it down?
chevynovaman 01-19-2010 06:29 PM
TIP
I HAVE SEEN THEM DO THAT WITH A BENT ROD.... GOOD LUCK
cepx111 01-19-2010 10:33 PM
Re: 427 BBC crank making contact with piston
Al
Pin bearing, whats that?
X2 on what he said....
Pull the rod/piston and have it checked out.
oldandtired 01-20-2010 05:50 AM
[quote="cepx111"]
x3 Bent rod - does not take much.
Dave
