-   -   How many guys use Oil catch cans (https://www.racingjunk.com/forums/showthread.php?t=26969)
CustomTanks 01-12-2010 10:47 AM
you guys use Oil catch cans,
If so what fittings AN or npt?
chevyfireball 01-13-2010 12:41 AM
Got a Moroso catch can with AN fittings. Its 1 litre. We have just be told be now need a 4 litre can mounted in the trunk.
mopar1968 01-13-2010 06:46 AM
I own a Mopar so therefore mine don't leak oil, So i don't need a catch can :!: :!: You must own a chebbie that leaks :!: :!:
BEAST477 01-13-2010 02:26 PM
Mopar you have to put oil in it and run it to get it to leak. :shock: :lol: :lol: :lol:
zipper06 01-13-2010 04:06 PM
Was that by the sanctioning body in NZ? It's probably a good idea as fast as you're running if you ever burned a piston on a run that 1 litre tank would fill up in a second and would be a recipe for disaster. Being in the trunk would clear the slicks if that were too happen.
chevyfireball 01-14-2010 01:41 AM
Yep. The NZDRA changed the rule this season. It is a good idea but a pain in the arse too.
