chevy 355 horsepower?
I'm building a 355 chevy for a 84 4x4 truck but i want it to run really good but it's the first engine ive ever built I will list my parts and you estimate the hp and offer any help i'm willing to take advise thanks.
bottom end it's a 1990 2 bolt main block it's 30 over new freeze plugs cam bearings eagle cast steel crank eagle sir i beam rods keith black flat top silverlite pistons and hasting rings top end procomp aluminum heads 202\160 200 cc 64cc chamber crane cam and lifters 278 450 lift roller rockers holley intake and carb i'm sure i'm forgetting something but thanks |
:D :D Good to see you are building something....but why not throw a strokedr crank in it and make it a fire breathing 383 or more......might just like that truck then......est on your combo poss 400-450hp....change the cam and throw a stroker crank in it est up to 600-650hp that will break the tires loose :D :D
Everything sounded good till you said the procomp word :shock:
what would you recommend this is going in a truck i drive every day to work that's got a stock 305 in it now
all around great drivability and durability but around 400-450 horsepower
do you have the listed parts or are they the ones that you are considering?
cheap,reliable,strong ...you can only have 2 you pick
I got an idea to get that 450 HP figure and be durable and cheap. build it with the parts you have. Then get a NO2 system with a 250 HP plate at a swap meet. Then you can have the 450 HP reliable and cheap. JUST NEVER USE THE NO2, EVER. :wink:
The crate engine idea is a good one, that will let you get assembly experience without the trouble of getting machine work checked and get a warranty. You can always add on later to the combination. Bruce |
| All times are GMT -8. The time now is 09:19 AM. |
