-   -   HOW MUCH HORSEPOWER? (https://www.racingjunk.com/forums/showthread.php?t=22401)
gmpartsman 11-30-2008 05:03 PM
I KNOW THIS IS SOMEWHAT OF A OPEN ENDED QUESTION BUT I AM GOING TO ASK ANYWAY..
i have a 71 nova backhalf car with a smith-racecraft tubular front end car weighs 2925 loaded,th400 right now, and a 4.30 gear..does anyone know approx how much hp it would take to get this thing into the 8.60-8.80 range?.
or is there a site that you can offer up info and get a approx number..
thanx for any input
FAT622 11-30-2008 05:21 PM
A moroso slide calculater is a very good guide.
dparker 11-30-2008 06:16 PM
Go to this website and you can plug in the numbers you want to acheive it will tell you how much HP it will take. Use the HP calculator part.
http://www.1bad69.com/calc.htm
zipper06 11-30-2008 06:24 PM
Another set of calculators
http://www.wallaceracing.com/Calculators.htm
I972Nova 11-30-2008 07:24 PM
My drag software says that 900 hp and 830 foot pounds, such as the Ohio Crankshaft Super 620 would put you at 8.804 in typical weather conditions.
gmpartsman 12-01-2008 04:59 PM
thanks. this is just what i was looking for..appreciate the help
russ67chevelle 12-06-2008 09:48 PM
i dont know tire size but to spin your car 155 mph which is about 8.7ish then with no converter slippage motor will be spinning about 7500 rpms with a 30 inch tire...something to keep in mind
dparker 12-07-2008 12:30 AM
Yeh, but who runs a 30 inch tire on a 8.70 car. Its only 6800 rpm with a 33 tire.
