wich trans to get?
i want a power glide,and the moter is about 575-600 HP,,the bracket racing powerglide from TCI want work will it, http://www.jegs.com/p/TCI/762162/10002/-1 it will be going in a 1500-1700lb dragster,,thanks steve
can you get the super street fighter in a powerglide
http://www.jegs.com/p/TCI/757655/10002/-1 |
Re: wich trans to get?
My best suggestion for you is this, get the best you can for the $ you have to spend. Do NOT buy anything with a 1.82 gear set. The 1.76 gear set will be fine, CI #890-715176 Bracket Racing Powerglide Bracket Brake 1.76 Ratio Shorty Length of course this is if you are dead set on a TCI, there are other good brands out there for what would be close to the same money. Coan, Hughes, TSI just to name a few. I would call all of these companies find the best deal for the money and go with that one. |
thanks David,,but it says not to use with over 450HP,so you say it will still work with about 600HP,,thanks Steve
The 1.76 gear set can be used with well over 600hp, one thng I notice about reading this they mention the 1.82 gearset now that one I wouldnt run over 450hp for sure, some get lucky with them being a dragster is so light. I've ran the 1.76 coan powerglides with 900hp bbc and no issues. I think if you were to call TCI they would tell you it must be a typo on jegs. Our Bracket Racing Powerglides are designed specifically to give you dependable service and great performance at an economical price for the mild engine bracket racer. This bracket racing series is not recommended for applications utilizing engines with over 450 horsepower, but is an excellent choice for engines making less than that. All 1.82 Ratio Bracket Racing Powerglides include a special reinforced stock planetary. A steel girdle is welded over the housing, which increases torque load capacity. All Shorty Bracket Racing Powerglides include a re-splined and heat-treated output shaft and shorty cover. |
I run a 540 CI BBC in a 3100 lb car with stock 1.76 planetaries.
I would just get a good trans man to build ya one...they are around.just got to look a little bit... Don't know what one costs from TCI but pretty sure you will still need to give them a core.Plus if you have problems what would you rather do? Talk to your tranny guy you met at the track, or ship it back to TCI or whomever and deal with that headache. JMO but I know a very good tranny guy that drag races |
TCI is pretty good. I also have had good service with BTE.
thanks guys,,david i was not questioning you,i just seen that on there was the reason i ask,thanks steve
BTE is my recommendation... :wink:
Call Steve here, you'll get a little better deal and a good job as well.
http://www.oldanimotorsports.20megsfree.com/ |
| All times are GMT -8. The time now is 04:50 AM. |
