-   -   building a street stock (https://www.racingjunk.com/forums/showthread.php?t=21662)
bart600R 08-20-2008 02:51 PM
I'm thinking of building a street stock. i have a 89 camaro iroc. what is the best set up for this car? should i go 305 or 350?auto or manual? and what gears?i've raced in the past but it was in the 1/4. wanted to try somthing different. do you guys khow any good websites? thanks alot
Tod74 08-20-2008 02:55 PM
powerglide built for circle track if the rules allow...if not run an old saginaw three or 4 speed. My uncles run a very expensive trans that is weird...you push the clutch in to take off or something like that...some sort of direct drive crap...will need to ask them the details cause I may have screwed up that description.
deward 08-20-2008 04:05 PM
Street Stock
Go with the the 350 cc if your rules allow it. The powerglide is a good trans for circle track but they can get pricey. Have a good shop "chassis" your car and you will save time and money in the long haul. :D
bart600R 08-26-2008 12:38 PM
do you guys know what gears i should go with if i do a 350 and a power glide
bart600R 09-16-2008 05:41 PM
bbchevy 09-16-2008 07:08 PM
MORE INFO?????????
NEED MORE INFO......................?
Dirt or Pavement?
1/4,3/8 or 1/2?
Heres the Deal i can HELP you With?
The Last Car i Built was for a Dirt 3/8 mile Track.
Motor?Sometimes,Mostly 383 other Times 355.
P/Glide Trans-You dont Need anything Special!!! 500-600 MAX!
Car Had to Weigh 3200 with a 4BRL,3100 with a 2BRL
9" Ford Rear,6.30 Ring and Pinion,and a 6.50,MOTOR Change would also Change the Gear!
The 383 would Turn about 6300 to 6500 down the Backstrech.
The 355 would turn right at 6800.
This Car would Run in the Top 5 every NIGHT!
And with the Rite SHOE,it was HARD to BEAT!!!!!!!!!!!!
Later
G 8)
bart600R 09-23-2008 01:12 PM
thanks im running pavement,3/8 mile track
NorthMotorSports 09-24-2008 09:54 AM
Go to racinboys.com they will point you in the right direction :D
