GM crank and roller rockers.
Will a BBC GM steel crank handle 750 HP, also uluminum or steel roller rockers?
Yes, if set up properly.
I like the comp cams pro magnums in steel or the T&D machine shaft mounts in aluminum. Both are good, it just depends on how much money you want to spend? JMO Cp |
Re: GM crank and roller rockers.
jmo |
| All times are GMT -8. The time now is 02:22 PM. |
