-   -   small block chevy (https://www.racingjunk.com/forums/showthread.php?t=20325)
gpracer 03-23-2008 08:14 AM
small block chevy
i have a 377 and just found out number 7 cylinder is dead no compression took it apart and can find nothing visully wrong can anybody tell me what to do next or if u have had this problem and what i need to do to fix it thanks guys
johnracer 03-23-2008 08:48 AM
A leak down test could have told where the compression was going before you took it apart. With no compression at all, you probably have a valve that is bent or not seating. Try filling the #7 ports or combustion chamber with water or solvent and see if the valves hold....
gpracer 03-23-2008 06:00 PM
small block chevy
thanks i did put fluid in ports the intake leaked right away so does that mean a valve job then all fixed??
johnracer 03-23-2008 06:33 PM
I'd get that fixed, bolt the head back on and perform a leak down test to confirm that the rest is ok. Might be best to make sure your piston to valve clearance is good if the valve is bent.....
sg5492 03-23-2008 06:45 PM
I always run a leak down test before I pull them apart. You can get alot of info from that test.
gpracer 03-23-2008 08:33 PM
small block chevy
thanks for the info i have another set of heads gonna bolt them on and see what happens and do the leakdown test i hope all is good any more info would always help
zipper06 03-23-2008 08:58 PM
X2,
it's hard to realize that (O) compression can not be seen if it's valves, they should be bent really bad.
Let us know what you found?
gpracer 03-29-2008 04:37 AM
small block chevy
i bolted on another head and got compression so i know its in the head so i am taking the heads in for a valve job and check for cracks thanks guys for your input have a great day
gpracer 04-06-2008 06:15 AM
small block chevy
thanks guys motor all back together and running good just some fine tuning and be ready to race thanks agian :D
