bad water pump?
I think I might have a bad water pump on my big block. The transmision is slipping so I adjusted the pinion angle to -3.1234 deg.
I then talked to a local race motor builder and he said that big blocks will spin the rod bearings if you don't have a nuetral safety switch hooked up...so I took the jets out of the carburator and it ran great for awhile...but now the left rear tire keeps going flat....I think maybe the water pump is bad or the fuel pump... Any ideas? |
Your probably correct, but you might check the kanooter valve...
re; bad water pump
Rollers or flat tappet, solids or hydraulics? A bad Kanooter valve, will cause it to detonate! Check your rear seal. Don*t know about the pinon angle though, Are you running oil restrictors, Also if the spring gets lodged in the oil screen, it could cause a springy pickup.
suicidebomb |
I LOCTITE MY ROD BEARINGS IN MY BBC!!!
Re; bad water pump
Calm down dude, of course I know that reseting the pinion angle will screw up the fuel pump! I just didn*t want to hurt his feelings.
I believe you have a flux capacitor problem......it's what makes time travel possible.
Re: re; bad water pump
suicidebomb |
for the record, I started this "in the pits" it was moved here. :D
I HAD TO PUT 125 POUNDS OF HELIUM IN MY DRIVESHAFT TO KEEP MY SBF RUNNING COOL[ WITHOUT THE COMP VALVE HOOKED UP :cry: :cry: ]
re; bad water pump
THATS RIGHT!!! we had a bad kanooter once that caused us to have to use a rather unorthodox fuel... Coleman fluid, we set our total timing to 13*. We burned up the upper drive flange, dumba$$ us we forgot to chamfer on the block side! Tee Hee we*ll never do that again!!!
| All times are GMT -8. The time now is 09:58 PM. |
