-   -   496 bbc (https://www.racingjunk.com/forums/showthread.php?t=19334)
blowenbig 12-29-2007 07:17 AM
496 bbc
Hi i am looking at a 496 but i am not 100% sure if it is he said that its the stock 454 block thats bored out then he has a storker kit is it possible with a stock bb or do you need a tall deck
thanks
mytmouz 12-29-2007 07:29 AM
It's possible...
hammertime 12-29-2007 09:00 AM
Re: 496 bbc
thanks
I wouldnt want a tall deck personally but either way can be done. A 496 in a sotck 454 block is very common. Just tell him you want the casting # off the block and look it up to see what it actually is.
blowenbig 12-29-2007 02:55 PM
thanks
bigstu 01-02-2008 11:09 AM
I had one built with a standard deck 454 block. The 496ci was accomplished with an .060 overbore and 4.25" stroker crank as for the 454's crank measures 4.00".
olds48 01-02-2008 11:13 AM
The only difference I know of between a 9.8 or tall deck block is,on my 496 I used the short deck,which put my wrist pin right thru my oil control ring.That was with a 6.385" rod. Tall deck you can avoid that,I believe.Doesn't hurt anything at all.
thecker 02-01-2008 11:44 AM
What do people turn these 496 too? My brother is looking at one with eagle forged crank and h beam rods? I was just wondering with that long of a arm. I told him we will proably have to take the 5.14 out. He turns his 402 bbc to 7600 in the 1/4. thanks
hammertime 02-01-2008 12:31 PM
I wouldnt turn it 7600 do the rods have the good L19 bolts or no ?
I personally wouldnt want to take it over 7200-7300
thecker 02-01-2008 12:59 PM
That I do not know. He just called me yesterday about it. I told him probably try to keep it around 7000 so I was close. I will try ti find out what bolts are in it. Do you know of any pistons for sale ? I think this guy has the block,crank,and rods only. I told him not to offer too much because i've seen assembled ones from Nye's for 2700 something on here. Thanks for the reply David.
hammertime 02-01-2008 01:21 PM
Nye's has very good prices and are good to deal with.
