Belt Drives
Pro and cons on these SBC belt drives. I was ask this the other day at the drag strip. I have never used the Comp Cams drives... Comp Cams Hi-Tech Belt Drive #6500......Comp Cams magnum #6100 or Jesel KBD-31000..
JESEL ALL THE WAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have one and love it, plus it looks kool . jesel says you dont want an idler pulley, makes sence too , nothing to move or wear out! just my 2 cents. would never think of useing any other, ther quiet, dont transfer harmonics to cam from crank, hold timing, andyou can adjust timing easy.David,
I have the #6100 on my 434" motor(no idler) but haven't run it yet, but i also have a jessel on the shelf that i got thru a deal on ebay with some other parts, just in case the Com cam unit has a problem.
Zip. |
What about Xceldyne,I`m looking to get one,has any one tried one yet?
| All times are GMT -8. The time now is 10:48 AM. |
