-   -   zz502? crate problems (https://www.racingjunk.com/forums/showthread.php?t=1297370)
GSI_103183640487218328641 11-08-2021 05:04 AM
4 miles on new crate motor and rocker arm nuts backed off can,t wait to see what comes next .All the rocker ***** are galled.and looks like they are made of the powdered metal process .Chinese ? any Ideas this is the new zz502 deluxe engine also lots of dust in the pan when i pulled it to change it upon first arrival ,anyone experiance these problems.
ssikolc 07-04-2023 12:21 PM
Does anybody have any regrettable encounters first or secondhand, with the ZZ502? Over the top oil utilization, unfortunate workmanship, and so forth? I'm thinking about buying one and simply maintain that should get my work done. I will likely add a Holley C950 EFI to it. Stringently road use.
Alexand 01-30-2024 04:30 AM
From what you've described, it's possible that the rocker arm nuts were not torqued to the correct specifications during assembly. You'll need to return them to the specifications outlined in the service manual. It's also a good idea to check if the threads are in good condition.
bongdalu6vip 05-20-2024 08:31 AM
i like it and do you like it
moresteve 06-20-2024 08:48 PM
Hello,
It sounds like your ZZ502 deluxe engine might have quality control issues. Contact the supplier or manufacturer immediately to report these defects and request a replacement or refund. Ensure any future engine purchases are from a reputable source to avoid similar problems.
