Rims with screw holes
I have an extra set of rims that I used slicks on, screwed in. Can I remove the slicks and screws and run M/T Pro Bracket drag radials with the holes open? Will it hold it's seal? I don't think you can screw in drag radials because of the belt.
If you try it and they leak, you can have the holes welded up easily.
Thanks BigBlockMark. I heard some people use a glue or sorts to keep the seal with drag radials..... true?
They do glue radials because you cannot screw them, but I don't know what they use. You could go to the "Yellow Bullet" Forum and ask there.
Originally Posted by BigBlockMark
(Post 1537626)
| All times are GMT -8. The time now is 10:03 AM. |
