-   -   front end shimmy (https://www.racingjunk.com/forums/showthread.php?t=1290208)
mikeshemi 08-01-2017 07:34 PM
front end shimmy
I have a 98 camaro with a big block chevy engine. wilwood brakes all around. Stock front struts. Problem is after running 1/8 mile even if i just touch the brakes the steering wheel shimmys. The harder i push the harder the wheel shimmys. while coasting after run the car is fine. But touch brakes and woww look out. I've taken off rotors and put them on a brake lathe. perfectly straight. Put tires on a balancer and no problem. Realigned front end. nothing. cleaned rotors with 100 grit air sander. Bought new pads. Oh i have 10 runs on this setup. Shimmied 9 times. New bushings new tie rod ends, stock rack. I''m at wits end.,.could front end toe in be wrong for the big block chevy at 122 in 1/8. Stock factory setting on front end specs for alignment. Any suggestions will be appreciated. I'm sure this isn't something only i'm stuck with.
Harbone 08-02-2017 05:37 AM
Turn the rotors with an on car brake lathe. There is probably some run out on the face of the hub causing the issue. Turning on the car eliminates that problem and cuts them straight on the car.
mikeshemi 08-02-2017 05:48 AM
I put the stock brakes back on the car. I'm going out sat and i will get back to you with the results. Thanks for the reply
murrayjest 01-15-2023 07:09 AM
