-   -   Chassis dyno question (https://www.racingjunk.com/forums/showthread.php?t=17503)
woodsman 06-09-2007 03:30 PM
buffjhsn I was wondering if you got some ball park #'s I came up with 620 hp at the rear wheel an 689 hp at the flywheel. I think these calculators are close but I dont know about being spot on. Wesley
buffjhsn1 06-10-2007 02:41 PM
well i have a formula i use to get rear wheel hp.... it is as follows
hp=weight*200/et*et*et
hp=2750*200/8.962*8.962*8.962
hp=550000/719.8
hp=764
i went to tim mccamis like you said and used the calculator. it says that i have
755.1 rwhp and 981.63 at the flywheel.
i just have a hard time believing this pooch of mine make almost 1000hp... i also have a hard time believing i lose 230 horse to the tires....
i have used my formula on a buddies dragster that makes 900 hp on the dyno and he had 900 horse at the rear wheels on his best pass....so thats why i wanted some input. making 1.512 horse per cube is respectable outta a 505 with box stock heads and intake.
i don't believe that you lose 25% to the tires. i understand it takes hp to initially turn the drive train but everything you put into the rear gears, converter, and trans is multiplied to the tires. granted you lose some through converter slippage, but 25%???
once you get the mass moving in stays moving (newtons law)....
anyone have any thoughts on this???
buffjhsn1 06-10-2007 02:53 PM
what numbers and or calculator/s did you use?
woodsman 06-10-2007 03:38 PM
buffjhsn1 I used Wallace Racing Calculators (hp from 1/4 mph,et and weight calculator) I think they are the closest. I just put your et and weight in to get the #'s if you put in the MPH than you come up with 755hp as you did and that looks much better. Sorry if I stole some of your pony's. I am a little new at this and did not input all the info. Well I have learned another good lesson on RJ. Wesley
buffjhsn1 06-10-2007 05:17 PM
wesley,
no big deal, i dunno what is right or wrong. all i know is what it runs in the 1/4 and what it weighs.
woodsman 06-10-2007 06:26 PM
buffjhsn1 I think I am trying to help to soon. So will just sit back and let the boy's that know what they are talking about give the advice. And thanks for your understanding. I love this stuff and will get great enjoyment out of it. Thanks again. Wesley
skipjobe 07-21-2007 08:23 PM
The ET calculator says about 750 RWHP
